Tables on the following pages provide basic speed, feed and cutting data for some of the materials commonly used for prototypes. Use the tool manufacturer's data instead whenever it is available.
Mill Cutting Speeds (SFM) surface ft/min | ||
Material |
HSS |
Carbide |
Aluminum | 600 | 800 |
Brass | 175 | 175 |
Delrin | 400 | 800 |
Polycarbonate | 300 | 500 |
Stainless Steel (303) | 80 | 300 |
Steel (4140) | 70 | 350 |
Drill Cutting Speeds (SFM) surface ft/min | ||||
Material |
Drilling |
C-Sink |
Reamer |
Tap |
Aluminum | 300 | 200 | 150 | 100 |
Brass | 120 | 90 | 66 | 100 |
Delrin | 150 | 100 | 75 | 100 |
Polycarbonate | 240 | 160 | 120 | 100 |
Stainless Steel (303) | 50 | 35 | 25 | 35 |
Steel (4140) | 90 | 60 | 45 | 35 |
Never use tools that have been used to machine metal to cut plastic. The sharp edge of the tool will be compromised and cutting performance and finish will suffer. A good practice is to keep two sets of tools: one for plastic and one for metal. High speed steel cutters work best for plastics. Carbide cutters work better for aluminum and other metals. |
Cutting Feeds (IPR) in/rev | |||||
Operation |
Tool Diameter Range (in) | ||||
<.125 | .125-.25 | .25-.5 | .5-1. | >1. | |
Milling | |||||
Aluminum | .002 | .002 | .005 | .006 | .007 |
Brass | .001 | .002 | .002 | .004 | .005 |
Delrin | .002 | .002 | .005 | .006 | .007 |
Polycarbonate | .001 | .003 | .006 | .008 | .009 |
Stainless Steel (303) | .0005 | .001 | .002 | .003 | .004 |
Steel (4140) | .0005 | .0005 | .001 | .002 | .003 |
Drilling | .002 | .004 | .005 | .010 | .015 |
Reaming | .005 | .007 | .009 | .012 | .015 |
Best practice machining parameters for prototype and short-production milling are different than for mass production. Production machining is obsessed with minimizing run time and maximizing tool life because even small improvements per part can result in significant cost savings.
Prototype and short run production seeks to maximize reliability. Obviously, it does not make sense to risk breaking a tool or scrapping a part trying to save a few seconds if only making a few parts.
Tables 3.8 and 3.9 on the following pages list recommended machining parameters for prototypes. The values are relatively conservative and work well for materials and tool types listed on the previous pages.
For materials or tools not listed, consult cutting data from the tool manufacturer.
Recommended Machining Parameters | ||
Operation | Parameter | Value |
All | Clearance Height | 1.0 inch |
All | Feed Height | .1 inches |
All | Rapid Height | As needed to clear clamps and fixtures |
Mill (Roughing) | Stepover (XY) | 50-80% of tool dia. |
Mill (Roughing) | Stepdown (Z) | 25-50% of tool dia. |
Drill | Peck Increment | .05 inches |
Spot Drill | Dwell | .5 seconds |
Stock Finish Allowances (inches) | |||||
Operation |
Milling (XY) | .001 | .005 | .015 | .020 | .020 |
Milling (Z) | .001 | .002 | .005 | .005 | .005 |
Reaming | .005 | .010 | .012 | .020 | .030 |
Do not make the mistake of thinking that the only option when encountering a machining problem is to reduce feed rate. Sometimes that is the worst thing to do and decreasing speed and increasing feed may be a better option.
Be methodical. When a problem occurs, stop. Analyze what is happening, draw on all available resources, and then devise a solution to correct the problem. The Machinery's Handbook (Industrial Press Inc, 2008, New York, NY, ISBN: 978-8311-2800-5) contains extensive information about diagnosing and correcting cutting tool problems. This book is an essential reference for anyone using machine tools.
