New Renumbering feature in CIMCO Edit
From CIMCO Edit version 7.01.08, the new feature “Advanced Renumbering” has been available. With it, it is possible to take into account commands that use line numbers, such as P and Q.
You can add rules with trigger and labels, and you can easily save each renumbering setup for later using Rule Groups. See screenshots below.
The new function allows you to define rules and triggers for searching for code that calls line numbers.
Here is the result. G71 and G70 functions that use P and Q labels that reference line numbers (N) have been updated correctly.
