CIMCO Software 2026.01.08 released
CIMCO Software
- Change: Updated French translations in Tool Manager.
- Fix: Fixed issues with running multiple license servers on the same network.
- New: Tweaked cursor when resizing sub program HUD.
- New: Reverse post: manual tool change position. (S28846)
- Fix: Okuma reverse posts: OO88.
- Fix: Fanuc reverse posts: G50.1, G51.1.
- Fix: Reverse post: wrong entity by line number in some cases when using external subprograms.
- Fix: A circumstantial freeze when closing Backplot.
- Fix: Corrupt sub program HUD when Editing main program.
- Fix: Visibility state not being remembered when toggling geometries from ribbon bar.
- Fix: Siemens reverse posts: added R1000-R1299 variables.
- Fix: Reverse post: angular move issue in turning.
- Fix: Siemens reverse posts: MSG command not outputs message into simulation window. (S28577)
- Fix: Crash in remove chips.
- Fix: Collision detection not refreshing after changing tool/workpiece setting.
- Fix: Stock simulation when turning on an AC 5 axis milling machine.
- Fix: Centroid reverse posts: conditional expressions. (S26828)
- Fix: NC line highlight sometimes on wrong line when jumping to tool changes.
- Fix: Siemens milling reverse post: CYCLE800 retract position.
- New: Added official support for Microsoft Entra ID as a login module.
- Change: Improved Haas Serial Monitor to parse monitoring messages. Added MONITORPREFIX=\CR\LF\STX and MONITORSUFFIX=\ETB in mch file in [HAASMONITOR] section.
- Fix: Fixed issues with DNC-Max Server not recognizing new port types when adding ports.
- Fix: Added support for FEED Hold signal in RS232 protocol.
- Fix: Fixed wrong client count at the bottom bar of DNC-Max server application.
- Fix: Fixed issue with mdc port license granting at start up.
- Fix: Fixed default send directory issues for SSH protocol & CIMCO Windows Agent.
- Fix: Web Client: Added modified date to send window.
- New: Added an option to enable or disable TLS for MariaDB connections on the operator screen in the button function used for reading job data from the database.
- New: Added an On-Screen Numeric Keypad for operator screens.
- New: Advanced filter extended about M00, M01, M30 instructions.
- Change: Updated MDC notification log time in the database table to match the actual notification trigger time.
- Change: Updated MSSQL connectors to trust DB serve certificate.
- Change: Updated Excel export so that Microsoft Excel is no longer required on the server.
- Fix: Fixed issue where reports were generated with incorrect tables/graphs.
- Fix: Fixed issue with the advanced filter in the Heidenhain protocol where control modes were not properly evaluated and message variables 1–3 were not working.
- Fix: Fixed issue in Modbus protocol where debug messages were sometimes not populated.
- Fix: Fixed issue where making a copy of the selected operator screen copied the last operator screen from the list instead. (S28656)
- Fix: Fixed an issue where the input field on the Operator screen could lose focus.
- Fix: Fixed wrong title in Setup UI for Switches.
- Fix: Fixed issue where users were not saved after a fresh install until the DNC server was started.
CIMCO Software Manager
- Fix: Fixed several issues related to stability and error handling & NC-Base web clients now correctly consume a NC-Base client license instead of a DNC-Max client license.
