CIMCO Software 2026.01.11 released
- New: Reverse post: parametrized machine subprogram macros. (S29004)
- New: Improved stock compare performance.
- New: Support updated web license.
- New: Support threading tools with low corner radius and point corners.
- Fix: Better robustness on Intel Integrated Graphics.
- Fix: An issue where turret mounts would not load.
- Fix: Reverse post: spindle axis center issue in machine coordinates.
- Fix: Heidenhain reverse posts: wrong rotation axis movements in some cases.
- Fix: True vision rendering stale image during animation playback.
- Fix: Sharpened shaft/shoulder stock collision margins.
- Fix: Siemens reverse posts: $P_ACTFRAME. (S27059)
- Fix: Siemens reverse posts: $P_UIFR.
- Fix: Fanuc milling reverse post: rotated work offsets G10, G30.
- Fix: Save Setup not commenting Version Number when writing to top of NC file.
- Fix: Fanuc/Mazak milling reverse posts: G68.4.
- Fix: Fanuc milling reverse post: G82 dwell time.
- Fix: Mazak and Fanuc milling reverse posts: system variables #7001-7941.
- Fix: Siemens milling reverse post: G_BACK_TUNNEL.
- Change: Changed default value of "Show only ports allowed by NCBase" to be consistent across DNC-Max Admin & CIMCO Editor DNC-Max Admin plugin (defaults to false now).
- Fix: Fixed OPC UA monitoring by updating OPC and resolving dependency conflicts.
- Fix: Fixed issues with receive translators being applied to compressed files resulting in corrupt files.
- Fix: Web Client: Fixed issue with showing individual OEE Gauges in the historical dashboards.
- Fix: Web Client: Fixed issue causing live screen translations to not always load correctly.
- Fix: Fixed issue in the Heidenhain protocol where PLC data paths of type boolean returned the strings "True" and "False" instead of the expected values 1 and 0. (S29135)
- Fix: Fixed issue when automatically generated reports use incorrect locale settings.
