CIMCO Software 2026.01.12 released
CIMCO Software
- Change: Updated Japanese translations.
- New: Added optional synchronization command mapping for matching different command numbers, such as M770 and M775, in multi-channel synchronization.
- New: Faster machine model / stock collision detection when the machine is frequently in close proximity.
- New: More robust stock from STL when the STL contains internal geometry.
- New: Tool manager: added tool station number to "Advanced tool location" in turning/mill-turn mode. (S29248)
- New: Okuma turning reverse post: B-axis support. (S28045)
- New: Heidenhain TNC7 milling reverse post. (S24521)
- Change: "Ignore block skip" is moved from control settings to simulation settings.
- Fix: Fixed an issue where automatic sync alignment in Multi Channel view could leave the cursor on the wrong line after editing synchronized NC files.
- Fix: Reverse post: G65P9811.
- Fix: Okuma reverse posts: MSG.
- Fix: Reverse post: inverse time feedrate (G93). (S28811)
- Fix: Reverse post: lathe tool center compensation for tilt. (S28433)
- Fix: More robust machine model / stock collision detection.
- Fix: A turning issue on some milling machines.
- Fix: Fagor reverse post: "I" suffix support for move parameters.
- Fix: Fixed an issue where multiline replace could miss occurrences within the current selection.
- Fix: Fixed an issue where multiline replace would replace beyond the current selection.
- Fix: Scanning supports tool location values for custom tools.
- Fix: Siemens reverse posts: CYCLE800.
- Fix: Roeders milling reverse post: supported Heidenhain commands/cycles. (S29321)
- Fix: Heidenhain millturn reverse post: cycle 800. (S28427)
- Fix: Siemens milling reverse post: CYCLE977.
- Fix: Reverse post: lathe threading when simulating on milling machine.
- Fix: Fanuc turning reverse post: G76.
- Fix: Heidenhain reverse posts: APPR LEN.
- Fix: Mitsubishi turning reverse post: G74.
- Fix: Siemens milling reverse post: POCKET3/4.
- Fix: MacBundle issues when using custom configuration paths.
- Fix: Added possibility to use $Variables in default PC path in split window.
- Fix: Fixed issues & wrong error messages that sometimes occurred when adding a new port through the client.
- Fix: Fixed issues with environment variables in auto receive destination folder. (Fixed $ORGPATH, $ORGNAME, $ORGNAMENOEXT, $ORGDIR).
- Fix: Fixed issue with Remote Request & Auto Receive sheets sometimes being blank.
- New: Added an option to reopen a previously closed sub-screen when the active state is triggered.
- New: Added a 'Rebuild All' checkbox to the rebuild days selection dialog.
- Change: Simple MariaDB reconnections (error 2006) are no longer logged. Added database type information to the DNC Server log.
- Change: Updated the System Table view in MDC Client.
- Change: Updated SQL scripts creating the mdcemaillog, mdcconnections, and outputdevicelog tables to use nvarchar(max) instead of the deprecated ntext data type.
- Change: Updated Heidenhain protocol to take into account this option: [OPTION18] POLLGETERROR = Yes.
- Change: Updated the behavior of input field focus.
- Change: Added a message box when a file opened from an operator screen does not exist.
- Change: It is possible now to select multiple HTML reports as attachment.
- Fix: Fixed an issue where real-time DB tables of type Timeline were not properly aligned.
- Fix: Fixed an issue where real-time DB tables were not rebuilt during a partial data rebuild.
- Fix: Fixed a potential issue in MDC when updating database tables during recalculation.
- Fix: Fixed an issue where the report interaction option was not saved.
- Fix: Web client: Fixed an issue where an empty result from a job data query was not displayed correctly.
- Fix: Fixed FOVR calculating for some models.
- New: Web Client: Added button to associate file with program.
- New: Added 2 new options under Server Settings > Logging to disable the remember last value behavior of 'Log Prompts' and 'Change Comments' respectively.
- Fix: Fixed an SQL error when searching for programs in NCBase when using MSSQL.
- Fix: Fixed an issue with saving NCBase parameters to the database when MSSQL is used.
- Fix: Web Client: Fixed issue with printing files.
