CIMCO Software 2026.01.13 released
  • New: Thermwood Milling reverse post. (S26367)
  • New: Okuma milling reverse post: G469. (S28132)
  • Fix: Mitsubishi reverse posts: spindle commands S1/2/3.
  • Fix: Siemens reverse posts: _TC_A1/2 variables. (S29462)
  • Fix: Tool color not working when setup file scanning was disabled.
  • Fix: Slow solid removal animation in some cases when rewinding.
  • Fix: X or Y axis cylinder stock sometimes initially disappearing.
  • Fix: Heidenhain TNC7 reverse post: TCPM error message.
  • Fix: Coolant state output. (S29430)
  • Fix: Reverse post: rotation time calculation.
  • Fix: Siemens reverse posts: calling subprograms starting with %_N_<name>_SPF. (S28394)
  • Fix: Fanuc milling reverse post: G53.1.
  • Fix: Updated the CIMCO Windows Agent to handle folders containing a large number of files.
  • Fix: Fixed race-condition sometimes preventing the client from adding ports.
  • Fix: Fixed an issue when inserting a new row into RT DB tables when Oracle is used.
  • Fix: Web Client: Fixed hour intervals in historical dashboards for when ignoring schedule.
  • Fix: Fixed issue in the NC-Base converter preventing conversion of drawing number field.
