CIMCO Software 2026.01.14 released
  • New: Optimized Editor startup time.
  • New: Simulation window loads faster.
  • Fix: Siemens reverse posts: max tool number is changed to 99999999.
  • Fix: Mitsubishi turning reverse post: spindle speed S1/2/3, tool correction G0 T*.
  • Fix: Fanuc milling reverse post: #0 variable comparison.
  • Fix: Fanuc milling reverse post: G10L12.
  • Fix: Centroid milling reverse post: G43.3, G0 interpolation. (S28768)
  • Fix: Reverse post: work offset system variables assignment issue.
  • Fix: MillPlus milling reverse post: G7.
  • Fix: Siemens milling reverse post: CYCLE840.
  • Fix: Reverse post: tool vector producing incorrect rotation in some cases. (S29496)
  • Fix: Siemens reverse posts: M7/8/9. (S29430)
  • Fix: Siemens reverse posts: supported rounding (RND) of arc-line and arc-arc corners. (S28559)
  • Fix: Haas reverse posts: supported work offset system variables #7001-#7386, #14001-#15966.
  • Fix: Fixed issue with sending large programs via the FOCAS 1 protocol.
  • Fix: Fixed issue with license counts after installing new license.
  • Fix: Fixed issue with DNCMax client showing deleted users when logging in using NCBase passwords.
  • Fix: Fixed the limit on the number of items in the split window. (S29466)
  • New: Added new time expressions:TIME[NOWDAYNUMBER], TIME[DAYSTARTNUMBER], TIME[DAYENDNUMBER], TIME[ISWEEKSTART], TIME[ISWEEKEND], TIME[ISMONTHSTART], TIME[ISMONTHEND], TIME[NOWDAYNUMBER], TIME[NOWWEEKNUMBER], TIME[NOWMONTHNUMBER], TIME[NOWYEARNUMBER], TIME[DAYSTARTNUMBER], TIME[DAYENDNUMBER]. (S23391)
  • New: Added regular expression for a custom variables (OPC, MTConnect, Brother)
  • New: Added support for Firebird DB in ExternIO.
  • Change: MDC formula dialog in the Events source sheet now also lists TEXTVARs. (S29343)
  • Fix: Fixed issue with custom variables in Haas M-net protocol. (S25167)
  • Fix: Improved a resolution of timeline in HTML reports. (S27777)
  • Fix: Fixed an issue where live and operator screens in thick clients could stop refreshing data after a live configuration change. (S28512)
  • Fix: Fixed issue with not working CNCINFO[xxx] expressions. (S29465)
  • Fix: Updated MDCMaxCMD.exe to be correctly aligned with report and table IDs.
  • Fix: Web Client: Fixed state name to system name conversion for accented letters in Historical Dashboards.
  • Change: Updated SQLAPI to version 5.4.2.
  • Fix: Fixed issue with incorrect user logged off log messages if DNCMax plugin was enabled.
  • Fix: Fixed NCBase Backup Server failing to cleanup temp files in some cases.
CIMCO Software Manager
  • New: Added new feature to remotely update the license file.
