CIMCO Software 2026.01.15 released
- Fix: Error when saving MacBundle.
- Fix: bug with not loading encrypted machines.
- Fix: Siemens reverse posts: CTRANS. (S29639)
- Fix: Siemens turning reverse post: CYCLE800.
- Fix: Fanuc milling reverse post: G10L12R.
- Fix: Heidenhain milling with turning reverse post: wrong retracts.
- Fix: Siemens milling reverse post: G75.
- Fix: Siemens turning reverse post: W collinear axis.
- Fix: Tool manager: High feed mill tool shape.
- Fix: Mazak Integrex reverse post: M153/154.
- Fix: Fanuc reverse post: issue with undefined subprogram arguments.
- Fix: Siemens reverse post: external subprogram call by file name.
- Fix: Okuma turning reverse post: TD, M323, G126/127, G136.
- Fix: Siemens reverse posts: supported $AA_IM[] variables.
- New: Introduced $PREV expression in the advanced filter and added check for each change option for a formula evaluation.
- Change: Fixed an issue where numeric values in real-time DB tables configured as TEXT were returned incorrectly.
- Fix: Fixed issue when html report was not send as pdf if only as pdf was checked.
- Fix: Fixed issue with saving Field Folders settings.
- Fix: Fixed issue with NC-Base not updating modified time for programs in Microsoft SQL.
- Fix: Fixed issue with Database files outside the NC-Base directory opened in the editor not closing when being auto logout was executed.
- Fix: Fixed issue with users in rare cases being allowed to save files while not logged in.
