CIMCO Software 2026.01.19 released
  • New: Custom lathe holder STL is now used without a profile.
  • New: Remembers work offsets in file type.
  • New: Brother milling with turning reverse post. (S28627)
  • New: Show active dynamic offset.
  • New: Added Backplot, NC-assist, Multi-Channel View and Advanced Math Functions to CIMCO Edit Core.
  • New: Added collision and limit over-travel report to CIMCO Edit Pro.
  • New: Added stopping conditions to CIMCO Edit Pro.
  • New: Added collision highlight to CIMCO Edit Pro.
  • Fix: Mazak reverse posts: G53.1, M107/108.
  • Fix: Editor jumps line when editing NC code.
  • Fix: An issue where cross section was off center.
  • Fix: An issue where cross section didn't always save state properly when toggling.
  • Fix: Siemens turning reverse post: TRAORI.
  • Fix: Mazak Integrex reverse post: G97R, G43.4P.
  • Fix: Fanuc milling reverse post: #999.
  • Fix: Millplus reverse post: G22, G23, G29.
  • Fix: Multiple scanned geometries using same STL but different transformations.
  • Fix: Haas reverse posts: M97, G103.
  • Fix: Millplus reverse post: G74. Added home position control settings.
  • Fix: Tool vs fixture collision detection in Backplot mode on lathes.
  • Fix: Y axis turning issues.
  • Fix: An issue where remove chips could remove the entire stock model.
  • Change: Better port logging of port licenses when a port is denied.
  • Fix: Updated CIMCO Agent to handle very large files.
  • Fix: Fixed issue with port licensing after applying global port change.
  • Fix: Fixed issue with global port change regarding port licenses.
  • Fix: Fixed race condition in regards to license port count.
  • New: Added a HELO host name option to the Notification SMTP interface. Updated the SMTP debug log.
  • New: Added a bridge mode for the FOCAS protocol as a workaround for a bug in the FOCAS library that can cause it to hang under poor network conditions.
  • Fix: Fixed an issue in the System table view where 'Find All' was not working.
  • Fix: Fixed custom variables in the MNet protocol.
  • Fix: Changed a default location of reports to …AppData… if not specified in configuration. (S29948)
  • New: Added options to automatically update existing memo files, tool lists, and setup sheets when a program file is saved, updated through Auto Import or Auto Receive, or accepted from the Import Queue.
  • New: Added new setting "Lock new programs", which locks newly created programs.
  • Change: The maximum available size of program fields in NC-Base is now determined by the actual column size in the database.
  • Fix: Fixed program update processing occurring before the edited file was successfully saved.
  • Fix: Fixed crash in Execute settings sheet that could occur.
  • Fix: Fixed an issue with the Oracle database upgrade to DB version 8.02.08.
