CIMCO Software 2026.01.21 released
  • New: Crisper rendering when windows scaling is 125%, 150% or 175%.
  • New: Better frame rate when windows scaling is 175% or above.
  • New: Turning inserts can now be seen through the holders.
  • New: Crisper text rendering.
  • Fix: Turning reverse posts: wrong moves on sub-spindle when in inches.
  • Fix: Now doesn't revolve the table for turning moves that position the spindle.
  • Fix: An issue where custom tool profiles with multiple adjacent arcs could corrupt stock simulation.
  • Fix: Custom tool from DXF when containing 180 degree arcs.
  • Fix: Measure distance edge and corner highlight would sometimes appear when not measuring.
  • Fix: Okuma reverse posts: MODIN, MODOUT.
  • Fix: Haas reverse posts: fixed DPRNT, POPEN, PCLOSE warnings.
  • Fix: Okuma turning reverse post: G20.
  • Fix: Fanuc milling reverse post: M29.
  • Fix: Mazak reverse posts: G84.2.
  • Fix: Turning reverse posts: wrong turret head moves at the first tool change.
  • Fix: Stock from DXF when DXF contains lwpolylines.
  • Fix: Fixed a potential crash in the DNC Server setup when copying an IOLogic unit.
  • New: Added Windows Agent support to the Flat File protocol.
  • New: Added a new option to the Heidenhain COM protocol to disable the Heidenhain 'Automatic Event Interface' as a workaround for issues with buggy TNC 640 controls running software version 340590.
  • Change: Updated the Heidenhain Direct protocol to minimize machine polling.
  • Fix: Fixed an issue in the MQTT UI where deleting a parser set could remove the wrong set.
  • Fix: Fixed an issue in the MQTT protocol when the client ID was not unique.
  • Fix: Fixed a bug in the Operator real-time database table when using the CTIMEFORMAT type.
  • Fix: Fixed Focas offline timeout setting being ignored.
  • Fix: Fixed a potential issue where generating multiple email reports could result in incomplete reports. (S28428)
  • Fix: Fixed an issue that could prevent the NC-Base service from starting after certain Windows updates. (S30164)
  • Fix: Fixed NC-Base editor saves incorrectly triggering update processing for unchanged files.
