CIMCO Edit Integration for Autodesk Fusion®
We are excited to announce a new integration for Autodesk Fusion® that brings CIMCO’s simulation capabilities directly into the Fusion environment. The integration is designed to make it easier to move from CAM programming to simulation, without having to recreate the setup.
Launch CIMCO Simulation Directly from Fusion
From within Fusion, the user can launch the various CIMCO simulation modules, depending on the task. The integration adds dedicated ribbon buttons that allow you to either run an internal simulation using CIMCO Edit Verify, or launch the external CIMCO Edit Professional for full NC code simulation, in either Backplot or Machine Simulation.
When using CIMCO Edit Verify, we read the toolpaths directly from the Fusion CAM operations. As this data comes straight from Fusion, the simulation loads very quickly and reflects the current state of the programming. This makes it suitable for verifying operations during the creation of your Fusion program, checking material removal, and identifying potential collisions as you work.
Final NC Code Verification with CIMCO Edit Professional
For the final verification, the integration allows you to export your Fusion setup and launch CIMCO Edit Professional to simulate the posted NC code. In this workflow, the NC code is read and simulated using the actual machine control selected in CIMCO Edit, such as Fanuc or Heidenhain. This means there is no need for special machine simulation post processors, and the simulation reflects what will actually run on the machine. The user can also edit the NC code and immediately see the result in the simulation.
With the integration functionality, we transfer the full Fusion setup into CIMCO Edit, including tool assemblies, stock, fixtures, workpieces and work offsets. This ensures that the simulation environment matches the CAM setup and removes the need for manual configuration.
Shared Machine Simulation Setup
Machine simulation is supported in both workflows when CIMCO Edit is installed. The integration uses CIMCO Edit Professional machine configurations and can launch machine simulation directly inside Fusion. This allows both internal simulation and NC code simulation to run on the same machine setup, making it easier to move between the two without changing configuration.
Currently, the integration supports milling operations, including 3-axis, 4-axis, and 5-axis machines. Additional machine types available in CIMCO Edit, such as turning and more advanced configurations, will be supported as Fusion’s internal simulation capabilities are extended.
With this integration, we connect Fusion directly to CIMCO’s simulation tools, making it possible to go from program creation to verification using the same data and setup throughout the process.
More information and Download
