A fixture plate is a work holding device used to hold thin parts that cannot be clamped in a vise. In prototyping, the plate is usually made of aluminum and is resurfaced and reused. Small fixture plates can be held in a vise and larger plates are bolted or clamped to the table.
Figure A.24 below shows an aluminum plate fastened directly to the machine table with a toe clamp: a low profile clamp that grips the edge of the plate and pushes it against the table. Once the plate is fastened to the table, face mill the plate to ensure it is flat.
Figure A.24: Fixture Plate |
Use caution when drilling holes in the fixture plate to not drill into the machine table. |
Figure in Table A.9 shows a fixture plate used to make Project 10: French Curve. This example includes many of the components used in fixture plates.
Clamps hold the plate down. Clamps are versatile, and can be moved between operations to grip the part in different places for different machining paths.
Dowel pins are used to precisely locate the stock or part. To ease pin removal, grind a small flat on the side of the pin. This allows air to fill the hole as the pin is extracted. Without a vent, the pin will be difficult or impossible to remove once installed.
Bolts are used to hold down the part after it is clamped and drilled.
Fixture Plate: Job-1 Setup | |
Datum: Upper-left corner of fixture plate. | |
Op-1 CTR Drill |
Center drill all holes. |
Op-2 Drill |
Drill .25 holes (3X) for dowel pins. Drill these just deep enough so the dowel pins extend about .25 inches above the plate face. |
Op-3 Drill |
Drill the holes for the #6-40 bolts that will be used to hold the part down while the OD is machined. |
Op-4 Drill |
Drill the holes for the ¼-20 bolts used to secure the custom clamps. |
Op-5 Tap |
Tap the #6-40 holes. |
Op-6 Tap |
Tap the ¼-20 holes. |
