Check List |
Buttons | |
1 |
Prepare:
2 |
MDI Mode: Select
3 |
Handle: As Needed
Note: Machine parameter 64 (T OFS MEAS USES WORK) must be set to OFF to use this method. | ||
4 |
Posit Button: Press |
5 |
Operator Screen: Select
6 |
Origin: Set
7 |
Handle: As Needed
8 |
Operator Z Value: Read
9 |
Offset Page: Set G54 Z Value
10 |
Numeric Keypad: Enter Z Value
11 |
F1 Button: Press
Tip Shift the datum DOWN by an incremental distance from the top of the part to remove stock from the top-face by subtracting the amount of stock to remove from the Fixture Offset Z Value. Example: To set the datum to Z-.02 below the top of the part: Z2.2080 |
