Check List
Buttons
1
Handle Jog Mode: Select
- This sets machine to be controlled by the hand wheel.
2
Jog Increment: .01
- This sets the job increment so each click of the hand wheel moves the tool .01 inches in the jog direction.
3
Jog Direction: Z
- This sets the tool to move in Z when the jog handle is moved.
Note: Machine parameter 64 (T OFS MEAS USES WORK) must be set to OFF to use this method.
4
Offsets: Select
- Press this button until the Tool Offset page displays.
5
Cursor Arrows: Align for active tool
- Use the Up-Dn cursor keys (if needed) to move the highlighted bar on the graphics display over the offset values for the currently active tool.
6
Use 1-2-3 Block to Set Tool Length
- Jog so tool is below top block.
- Apply slight pressure to block against tool. Use Jog Wheel to raise tool until the block just slides underneath it.
- Move block out of way and then move tool back down .01 inches below top of block.
7
Jog Increment: .001
- Reduce jog increment and use jog handle to raise tool in .001 increments until it just slides under the block again.
8
Tool Offset Measure: Select
- This causes the control to enter the current position of the tool in the length offset register.
- Make sure the tool length number updates before proceeding.
9
Next Tool: Select
- This causes the current tool to be put away and the next tool to be loaded.
- Repeat steps 1 thru 9 until all tools are set.
Tips
- Do not press any buttons between steps 8-9 or NEXT TOOL button will not load next tool.
- If you should press any buttons and interrupt this process, load the next tool by selecting the ATC FWD button, followed by HANDLE JOG.
